Can you help with the wiring diagram for this car radio.
Dec 6, 2022 at 11:34 PM
STEVE W.
✓Experienced Mechanic
Looks like there are a few versions for that car, both with and without the amp and with and without the auto-cruise. These diagrams cover all 4 systems. The first ones are the connectors and then the units with an amp. The only difference if it doesn't have cruise is the steering controls because it uses the lamp circuit in the steering wheel. The last 2 are the ones without the amp which eliminates the controls for the amp or cruise depending on the options. Hope these answer the question. I'm guessing you want to replace the OE unit. If so, be careful as the factory amp doesn't turn on or off with the radio, it turns on and off with the key.
Images (Click to enlarge)
Dec 7, 2022 at 1:38 AM
BOB 13
MEMBER
Hi, sorry, I should have stated that it's a 2008 Kia rondo Ex, 7-seaters fully loaded with 8 speakers and with an infinity amp under the driver's seat. Thanks, and sorry again.
Bob 13
Dec 7, 2022 at 1:46 AM
STEVE W.
No problem. That would be the first three images then.
Dec 7, 2022 at 2:30 AM
BOB 13
MEMBER
Hi Steve, my 1998 Ford Escort SE wagon, a 2006 or 2007 Ford Focus ZXW SES, and a 2010 Ford Focus SES sedan that I am looking into buying, do you have a radio diagram for these radios too, this is not strange I buy most all Ford cars, for the family.
Dec 7, 2022 at 6:09 AM
STEVE W.
Probably but we try to keep questions to one topic to make it easier to search. Just ask for those as new questions. Used to be Crutchfield had diagrams for connections as free, but they stopped that.
Dec 7, 2022 at 10:28 AM
BOB 13
MEMBER
Hi, is there a cost for the diagrams?
Dec 7, 2022 at 12:58 PM
STEVE W.
Not to our users. However, like every shop, we pay for access to the repair information. The reason for the extra questions is so that if someone else decides to look for say a Ford Focus wiring diagram, they probably won't be searching under Kia. So, we keep questions to one topic to make that possible.
Dec 7, 2022 at 1:54 PM
BOB 13
MEMBER
I will then ask the question in the Ford section. Will that be okay?
Dec 7, 2022 at 5:15 PM
STEVE W.
Yep. If you are looking for something specific in them, put it as the questions.
