I need a complete wiring diagram?
1,000,000 MILES • 3.9L • V8 • 2WD • AUTOMATIC
BRIAN CHILDRESS
  • 19 POSTS
I need a complete wiring diagram from front to back I have discovered some wires cut and missing and I need to know how to run new replacement wires and from where they start. Also I need to know how to program a pin code to unlock an lock the door I can't get the original code because I'm 3rd owner and I don't have the owner manual
Mar 18, 2022 at 3:27 AM
  • 55,688 POSTS
We can give you wiring diagrams, but you must tell us which system the diagrams are for? As far as the lock code you will need to call the dealer and give them your VIN# sometimes they are written inside the owner's manual. Let us know.
Mar 21, 2022 at 3:42 AM
BRIAN CHILDRESS
  • 19 POSTS
Left side of trunk wires are cut and I think some are missing.
Mar 25, 2022 at 12:33 AM
  • 55,688 POSTS
Left or right side, this is what they say is on the left side in the diagrams below, please confirm then I can give you the diagrams. Check out the diagrams (below). Please let us know what happens.
Mar 25, 2022 at 4:00 AM
