ALDL connector ?
53,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
KENPACH
where is the computer diagnostic port in my listed above? It is the coupe model.
Jul 25, 2017 at 12:10 AM
HMAC300
  • 48,601 POSTS
lower left of dash near brake pedal. See picture. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Jul 25, 2017 at 5:37 AM
BUGINGREASEMONKEY
  • 5 POSTS
my scanner will not connect to PCM. No power to plug. Need diagram of data link connector and what wire is the hot wire from the PCM?
Sep 10, 2020 at 4:18 AM (Merged)
SATURNTECH9
  • 30,869 POSTS
The orange wire is the power wire at the obd2 connector. That is usually the cigarette port fuse that powers the connector check all your fuses.
BUGINGREASEMONKEY
  • 5 POSTS
all fuses are good.i must have a broken wire some where. that is why I need a diagram.
WRENCHTECH
  • 20,760 POSTS
https://www.2carpros.com/images/external/78506441.gif
BUGINGREASEMONKEY
  • 5 POSTS
Thanks a lot it is just what I needed.
WRENCHTECH
  • 20,760 POSTS
You are welcome!
BUGINGREASEMONKEY
  • 5 POSTS
What should voltage be on the connector?
WRENCHTECH
  • 20,760 POSTS
Whatever battery voltage is at the moment.
BUGINGREASEMONKEY
  • 5 POSTS
Thanks on the same car the dimmer switch in the dash for instrument cluster has no power which wire is the hot wire? I have a white yellow green black.
JIMMY2510
i am tring to have codes read and the obd plug is not working. the code reader works fine on other cars but wont on mine? checked fuses
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
If you can, try using another scanner. You have to have a 12 V power source at that plug and communication. If you have 12 V and a good fuse then you have a communication issue with the ECM, it could be the ECM that's the problem. Make sure that the fuse is actually good, don't just look at it exchange it for a known good one or replace it with a new one if you're in doubt. Sometimes a bad fuse will look good
  • 55,710 POSTS
Please start a new question
Best, Ken
SHAGGY274
  • 7 POSTS
Car has Brand NEW Battery it will run, you can drive it, all the electrical componets work far as I can tell had the CHECK GAUGES and ABS warning light come on and it went off byitself I pluged my code scanner in to find out why and it said "(no power from vehicle)" checked fuses all fuses in fuse box under dash or good unpluged and plug back in the BCM and also unhooked both negative and positive battery cables and let sit for a lil bit then hooked them back up and got same message on code scanner.
DAN_K
  • 213 POSTS
A General Motors OBD-1 assembly line data link (ALDL) connector is not a powered connector like an OBD-2 connector.
(see picture below)
SHAGGY274
  • 7 POSTS
I have a Snap-on solus pro scanner and it want read the data in the OBD-1 what would make it not read the data?
DAN_K
  • 213 POSTS
It might be a good idea to refer to the user's manual for your scan tool as they are all somewhat different.
