Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Buick
Lucerne
Engine
Symptoms
Not Running
My car won’t run can we fix it?
2009 BUICK LUCERNE
200,000 MILES • 3.9L • V6 • 2WD • AUTOMATIC
DREDEEZY
MEMBER
my car won’t run can we fix it?
Jan 3, 2020 at 5:40 AM
Experienced Mechanic
This sounds like the crankshaft angle sensor or the fuel pump has gone out, when you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds? These guides should help us fix it.
https://youtu.be/dCjmRL3p4Cs
and
Also, lets run the codes to see what come up.
Jan 3, 2020 at 7:29 AM
DREDEEZY
MEMBER
thanks it was the engine crankshaft angle sensor i got a new one it started right up.
Jan 3, 2020 at 10:29 PM
Add image or video
Ask a new question
Engine won't crank
Engine stalls while driving
