Okay, so I have had this code for the thermostat and I finally broke down and change the thermostat and the valve cover gaskets, cleaned the plenum and what not. It was running good but now I get these codes C1298, I do have a small transmission leak from the cooler, but its controlled, also P0446, P0128, P0442 I noticed a small leak from the drivers side cat U1301, and U1040. It's using high fuel consumption and rpms are over rev. when starting to take off until about 2nd gear hard shift.
Mar 17, 2016 at 1:35 AM
