diagnostic codes
139,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
TAHRRINGTON1
I have a p71 police interceptor. I have replaced the transmission solenoids and fluids, but it still show codes p0755 and p0753 and the o/o light flashes when i drive it. vehicle does shift but not as smooth as i feel it can. no clanking or jumping when it shifts just a hesitation before it shifts to overdrive. i have reset the codes with diagnostic tool, but codes come back after driving it a few miles along with flashing o/o light. i am thinking the ecm is that a possible cause or should i look elsewhere? is there a way to test the ecm? Thank you.
Jul 16, 2016 at 7:22 AM
HMAC300
  • 48,601 POSTS
have a transmission professional look at it, it is either a valve body problem or a clutch seal/clutch pak. if you changed fluid and it was dark brown or black when you first pulled pan time for a rebuild. it also could be the clutch in torque converter is shot.
Jul 16, 2016 at 8:40 AM
