diagnostic
100,000 MILES
COOLCALI1965
my service engine light and brake light are on. I had the codes read and read I needed a new computer so I bought and installed a new computer but the lights are still on. Does this mean I have more problems and do I need to have my electrical system worked on or at least looked at? What could this be?
May 22, 2013 at 5:47 AM
SINBAD271
  • 169 POSTS
Check for codes for the check engine light, check your brake master cylinder see if it is low on brake fluid you may have a leak. That is if it is the red brake light that is on, check your e brake make sure it isn't slightly engaged. If master cyl is low of brake fluid how does your brake pedal feel?
May 22, 2013 at 2:38 PM
