diagnosis for DTC procedure without scanner
2008 NISSAN SUNNY
1.5L • 4 CYL • 2WD • AUTOMATIC
SAIMON
Dear sir,
help me please.
how to the test DTC engine check by bleeding without scanner.
Oct 22, 2015 at 3:16 AM
  • 31,937 POSTS
This car uses OBD 11 and can't be flash coded, you will have to get a scanner
Oct 22, 2015 at 9:31 PM
SAIMON
thank u so much
Oct 23, 2015 at 12:55 AM
  • 31,937 POSTS
A pocket scanner is quite cheap, it will only give you the codes and no data, but we can decipher the codes here if you need. Re post if you need further assistance.
Oct 23, 2015 at 3:14 PM
