Diagnosis codes 302 or 501
108,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
AMANDA BLEVINS
Can’t find out about either camshaft sensor or crankshaft sensor either 302 or 501.
Keep trying to reset codes but not correcting.
The car keeps losing power as we’re trying to drive it has no power and has little jerks as I’m trying to get it up to speed
Feb 20, 2021 at 6:57 AM
I am not sure if we have the same codes as the P0302 and P0501 are not for the cam and crank sensor.
I attached the info below for these codes and we need to run through both of these and figure out what the issue is. I suspect the speed sensor code (p0502) is causing most of the issues. However, you are not going to be able to just clear them so let me know what questions you have and we can go from there.
Thanks
Feb 21, 2021 at 8:25 AM
