Transmission not shifting into all gears?
25,000 MILES • 1.4L • 5 CYL • TURBO • 2WD • AUTOMATIC
SIYAMOSES
My car skips gears, it only allows gear 1, 2, 4, 6 only and it doesn't allow gear 3,5 and 7 I don't know what the problem might be, Even the Ignition sometimes is hardens so I struggle to twist the key so that it may start.
Feb 23, 2025 at 3:24 PM
STEVE W.
  • 15,410 POSTS
That car has what is called a DSG (dual shaft gearbox) that means it basically has one clutch that selects one set of gears and a second clutch that selects the other set of gears. In your case it sounds like the second clutch isn't operating. Unfortunately, that gearbox is also a known problem item because of its design and being less able to handle the engine's torque during "spirited" driving. The first step though is going to be to use a scan tool, which has bidirectional control, to look at the transmission control system and use it to test the clutch activation systems to see if the issue is in the transmission controls or if it's a failure in the clutch mechanically. The latter is common and generally requires that the mechanical clutch assembly be replaced due to physical damage.
Feb 23, 2025 at 9:04 PM
