Will not start and no connection on diagnostics
150,000 MILES • 2.0L • 4 CYL • TURBO • 4WD • MANUAL
PADDY IRL
My car was running bad. Wouldn't rev past 1,500 and very smokey and chugging while driving. thought it might be fuel so changed filter and it ran but still same. now won't start and can't get a connection on diagnostics.
Sep 3, 2019 at 1:17 AM
  • 55,721 POSTS
When you say wont start do you mean the engine is cranking over and not running or not cranking over? If it is not cranking over it sounds like the battery needs to be tested. here is a guide to help:
Sep 4, 2019 at 11:06 AM
PADDY IRL
Cranking but won't start.
Sep 4, 2019 at 5:38 PM
  • 55,721 POSTS
When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds? This guide can help us fix the problem:
Sep 5, 2019 at 5:05 AM
