Engine will not stay running
318,907 MILES • V6 • 4WD • AUTOMATIC
OMAR JATTA
when I started the car it run for few minutes it stop.
Oct 11, 2020 at 5:56 AM
Is there any more to this story? Did this just happen or was there an issue with the vehicle that you were trying to fix and then this happened? What does the vehicle do now? Does it just crank?
If it is only cranking, we need to run through this guide and see what turns up:
First and foremost we need to find out if there are codes.
If there are no codes, let me know what turns up with the first guide and the answer to the questions above. Thanks
Oct 11, 2020 at 7:27 AM
