Diagnose fuel pump
150,000 MILES
STEVE ATHERTON
Cranks over fine does not start.
Oct 13, 2018 at 6:50 PM
STEVE ATHERTON
The Vin number is jm0bl10f100189870
09/10. I think it is a 2.0 liter.
Oct 14, 2018 at 1:58 PM
DANNY L
  • 5,648 POSTS
Hello again.
Like you stated I would suggest checking your fuel pressure. Your in tank pump could be weak/failing/low on pressure. I am attaching a tutorial that shows what is involved in testing your fuel pump. If you do not have access to one, your local auto parts stores have a tool loaner program an can rent you one. The output fuel pressure on your car should be between 51-62 P.S.I. Hope this helps and thanks for using 2CarPros.
Danny-
Oct 14, 2018 at 8:31 PM
STEVE ATHERTON
Yes thank you, your advice was a great help. Thanks again.
Oct 14, 2018 at 11:20 PM
