Delayed starting
240,000 MILES • 4 CYL • MANUAL
DARKENDSTAR69
I have been having an issue with starting my car. It has a delayed start before it cranks, turns and start. During the delay there is nothing that shows it will start (I do have power to my car, radio, windows and everything work fine). I turn the key and it just seems like it is not going to start and then after fifteen to thirty seconds it starts up, sometimes it takes longer. I changed out the starter thinking that was going bad and the problem still persists. We also tried changing the starter relay and we checked the battery connections but did not find anything and still nothing is helping this issue yet. any ideas?
Apr 22, 2018 at 9:30 PM
Good morning.
When you try to start and nothing happens, it could be a feed problem to the starter. since it starts after trying several times, I would start by cleaning your battery cables of all build up. that will restrict voltage needed to make the car start.
if that is okay, I suspect an ignition switch that may have dirty contacts or damaged contacts not allowing current to flow.
Apr 22, 2018 at 9:55 PM
