defroster not working
78,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
CFRUSH1
  • 73 POSTS
i can't get air to defroster, heater still works.
Jan 30, 2021 at 1:05 PM
Most likely this is due to the mode door actuator has stopped working. This is responsible for directing the air from the panel positions to the defrost and it has stopped. Normally they default to the defrost position but it may be stuck. Normally you would be able to test this by seeing if the position moved to the floor from the vents but you have a separate actuator for the floor only.
I would go ahead and replace this and go from there. I attached the info below on how to replace it. Let us know if you have questions. Thanks
Jan 31, 2021 at 7:51 AM
  • 110,248 POSTS
On this vehicle, there is an actuator that is responsible for changing the airflow to the defrost mode. It sounds like it failed. What I would suggest is to remove it and see if it responds when you request defrost. Here are the directions for replacement. The pics attached correlate with the directions.
___________________________________________
2003 Lincoln Town Car V8-4.6L SOHC VIN W
Panel/Defrost Door
Vehicle Heating and Air Conditioning Air Door Actuator / Motor Service and Repair Procedures Blend Door Actuator Panel/Defrost Door
PANEL/DEFROST DOOR
REMOVAL
1. Remove the plenum chamber.
pic 1
2. Remove the screws and remove the panel/defrost door mode door actuator.
INSTALLATION
1. To install, reverse the removal procedure.
Take care and God bless,
Jan 31, 2021 at 9:29 AM
CFRUSH1
  • 73 POSTS
Will I need you remove dashboard first?
Jan 31, 2021 at 9:45 AM
  • 110,248 POSTS
This one is up high, but if you remove the plenum chamber, you should be able to get it.
Let me know if I can help.
Jan 31, 2021 at 11:09 AM
CFRUSH1
  • 73 POSTS
Joe,
Do yo have instructions on how to remove defrost door unit?
Thanks for the advice.
God bless you as well.
Feb 2, 2021 at 7:25 AM
  • 110,248 POSTS
First you need to remove the air duct system. Here are the directions. The plenum chamber removal will follow.
_____________________________________-
Instrument Panel Air Distribution Ducts
Vehicle Heating and Air Conditioning Air Duct Service and Repair Procedures Disassembly and Assembly Instrument Panel Air Distribution Ducts
INSTRUMENT PANEL AIR DISTRIBUTION DUCTS
DISASSEMBLY
1. Remove the instrument panel. For additional information, refer to: Dashboard/Instrument Panel. See: Dashboard / Instrument Panel > Service and Repair
2. Remove the audio unit.
pic 1
3. Remove the screws.
pic 2
4. Remove the screws and the LH demister.
pic 3
5. Remove the screws and remove the LH instrument panel duct.
pic 4
6. Remove the screws and remove the RH demister.
pic 5
7. Remove the screws and remove the RH instrument panel duct.
pic 6
8. Remove the screws.
9. Remove the plenum chamber, defroster duct and center instrument panel duct as an assembly.
ASSEMBLY
1. To assemble, reverse the disassembly procedure.
_________________________________________________
Removal and Installation
Vehicle Heating and Air Conditioning Housing Assembly HVAC Service and Repair Procedures Removal and Installation
REMOVAL AND INSTALLATION
REMOVAL
1. Disassemble the instrument panel air distribution ducts.
pic 7
2. Remove the screws and remove the center instrument panel duct.
pic 8
3. Remove the screw and remove the defroster duct.
INSTALLATION
This is a bigger job than I remember. Let me know if I can help in any way or if you have other questions.
Feb 2, 2021 at 11:39 AM
CFRUSH1
  • 73 POSTS
thanks Joe.
I will let you know if it is within my capability, otherwise I'll just get a dash fan.
Feb 2, 2021 at 11:48 AM
  • 110,248 POSTS
Sounds good. Let me know what you find or if you need help. I'll try my best from here to help.
Feb 2, 2021 at 11:49 AM
