Defrost does not work
59,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
BBBUBBA
Defrost will not work. is it a mode door actuator? How difficult is this to get to and could it be a DIY?
Jan 21, 2018 at 11:47 AM
Good morning.
Attached is a picture of the location.
Yes, it is an easy replacement. you need to remove the lower dash shield. that is on the left side by the gas pedal. once you remove that you will be able to access the motor. you can get the part at any parts store.
Jan 21, 2018 at 8:46 PM
