Defrost wires?
340,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
JOEPONTIAC
  • 13 POSTS
I want to add heated mirrors in my car.
My only problem now is identifying defrost rear window wires and then tap in there.
Thanks
Aug 31, 2022 at 12:08 PM
  • 110,246 POSTS
I attached the wiring schematic for the rear window defogger below. The pic was only one page long, but I cut it in half to make it readable for you.
I do have concerns about doing this. You are placing a heavier load on the circuit. It may cause the fuse to fail and more importantly, the defogger relay.
The relay isn't a traditional relay. It is not replaceable. It is part of a printed circuit board. If it fails, the only repair is the replacement of the box. That can get expensive.
However, that is your call. I just wanted to let you know about that.
Take care and let me know if you have questions.
Aug 31, 2022 at 12:54 PM
JOEPONTIAC
  • 13 POSTS
Thank you for letting me know.
I’m going to change my plan.
Thank you
Aug 31, 2022 at 5:47 PM
  • 110,246 POSTS
You are very welcome. I have a feeling you may regret doing it the way originally thought. Regardless, let me know if there is anything I can do to help.
Sep 1, 2022 at 12:02 PM
