Defrost vents will not adjust temperature
210,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
MICHAELBRAY19
When using my vents, I am able to adjust the temperature of the out coming air. When I am using my defrost vents it will blow either full hot or full cold but nothing in between.
Jan 1, 2022 at 11:56 PM
Just to be sure we are on the same page; the temperature works correctly at all times except when you are using the defrost? At that point it goes to full hot or cold? What do you have to do in order to get it to switch to the other temperature? Is there a certain point at which it flips temperature?
Also, it appears you have a manual temperature system. Meaning you have levers, and it moves cables?
If so, we may have an issue with one of the cables or levers in the control assembly. I am attaching the process below on how to remove and inspect it.
So, let's start with this and go from there.
Thanks
Jan 3, 2022 at 10:02 AM
