AC/heat/defrost not working
185,000 MILES • 4WD • AUTOMATIC
CHRISCHRIS4205
all of a sudden my AC/heat/defrost wont come on. it does put out a small bit of heat but doesn't blow anything out of vents.
Feb 5, 2021 at 10:15 PM
Can you hear the blower motor changing speeds when you turn it on high? If not then we have a blower motor issue and this should help with that.
https://www.2carpros.com/articles/low-or-no-air-flow-from-vents
However, if the blower motor is working then we have a door issue and this guide should help:
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
Let's get this detail about what the blower is doing and we can go from there. Thanks
Feb 6, 2021 at 9:43 AM
