There is just a tiny little bit of warm air coming out in the driver's side in the area for feet while there's super much hot air coming through at the passenger's side. The three smaller defrost heaters directly at the windshield don't work at all, there's no air coming through. The two larger heaters just a little further away from the wind shield work perfectly fine. As it is very cold right now, my windshield would freeze while driving. I tried to find hoses that have leaks but I couldn't. Is this a well known problem with the van listed above is the SE model and can I fix it by myself? What parts would I need and how expensive is it going to be? Unfortunately, I had to replace lots of things already and I just have the car for three months... Would be so grateful for your help!! Thank you very much!
Nov 23, 2020 at 8:08 AM
