Defrost
140,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
ALEXT53
When i turn my defrost on, it works on all parts except it does not blow out the driver windshield. So the entire car defrosts except the part i need to see out to drive. When i do turn it on high it makes a high pitch whining. I do not think its the actuator but i do not know. It is not stuck in defrost either.
Nov 15, 2017 at 3:02 AM
STEVE W.
  • 15,421 POSTS
Do you get any air out of the drivers defrost at all? High whine sounds like a blocked duct. It is one piece so if leaves or similar got in there and blocked it you would need to take out the dash to get the duct work out. If you look into the duct can you see anything?
Nov 16, 2017 at 6:37 AM
ALEXT53
There is no air coming out of the drivers defrost at all. I looked in there and there seems to be nothing blocking it or covering it.
Nov 17, 2017 at 12:01 AM
  • 55,808 POSTS
To me it sounds like the mode door actuator is not working but to be sure remove the actuator and then turn the system on and move the pivot back and forth to see if it makes a change and the defroster starts working.
Here isa guide to help see what I am talking about.
Here is the location for your truck (below)
Cheers, Ken
Nov 19, 2017 at 5:42 AM
