Codes P0138, P0172, and P2253, faulty new oxygen sensor?
205,000 MILES • 0.8L • 3 CYL • 4WD • MANUAL
ELDINE SULIVA MOLINA
  • 6 POSTS
may is ask if the new oxygen sensor installed was defective. as per using diagnostic tool, the status for the following code is "Stored": P0138, P0172, P2253.
Jan 21, 2021 at 8:46 AM
Good evening,
Yes, the new sensor could be the issue. Did you get an exact replacement sensor or universal?
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
The other 2 codes are related to running rich. The most common issue is the mass air flow sensor.
https://www.2carpros.com/articles/how-a-mass-air-flow-sensor-works-maf
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
DTC P0138: Heated Oxygen Sensor (rear) Circuit High Voltage
CIRCUIT OPERATION
A voltage corresponding to the oxygen concentration in the exhaust gas is sent to the ECM terminal O2RL from the output terminal of the heated oxygen sensor (rear).
Ground terminal of the heated oxygen sensor (rear) is grounded with ECM terminal ORLE.
The ECM applies an offset voltage of 0.5 volt to ground terminal of the heated oxygen sensor (rear).
TECHNICAL DESCRIPTION
The output signal of the linear air-fuel ratio sensor is compensated by the output signal of the heated oxygen sensor (rear).
The ECM checks for the heated oxygen sensor (rear) output voltage.
DESCRIPTIONS OF MONITOR METHODS
Heated oxygen sensor (rear) output voltage is over specified range.
MONITOR EXECUTION
Continuous
MONITOR EXECUTION CONDITIONS (Other monitor and Sensor)
Other Monitor (There is no temporary DTC stored in memory for the item monitored below)
Linear air-fuel ratio sensor monitor
Linear air-fuel ratio sensor heater monitor
Heated oxygen sensor heater (rear) monitor
Heated oxygen sensor offset voltage monitor
Sensor (The sensor below is determined to be normal)
Mass airflow sensor
Engine coolant temperature sensor
Intake air temperature sensor
Barometric pressure sensor
DTC SET CONDITIONS
Logic Flow Chart
Check Conditions
More than 2 seconds have passed since the engine starting sequence was completed.
Heated oxygen sensor offset voltage is between 0.4 and 0.6 volt.
Judgment Criterion
Heated oxygen sensor (rear) output voltage is more than 1.8 volts for 2 seconds.
FAIL-SAFE AND BACKUP FUNCTION
None
OBD-II DRIVE CYCLE PATTERN
Refer to Diagnostic Function - OBD-II Drive Cycle - Pattern 22 See: Computers and Control Systems > Monitors, Trips, Drive Cycles and Readiness Codes > OBD- II Drive Cycle .
TROUBLESHOOTING HINTS (The most likely causes for this code to be stored are:)
Short circuit in heated oxygen sensor (rear) output line.
Connector damage.
ECM failed.
DIAGNOSIS
Required Special Tools:
MB992745: V.C.I.-Lite main harness A
MB992747: V.C.I.-Lite USB cable short
MB992748: V.C.I.-Lite USB cable long
MB991958: Scan Tool (M.U.T.-III Sub Assembly)
MB991824: Vehicles Communication Interface (V.C.I.)
MB991827: M.U.T.-III USB Cable
MB991910: M.U.T.-III Main Harness A (Vehicles with CAN communication system)
MB991658: Test Harness
STEP 1. Using scan tool (M.U.T.-III), check data list item AD: Heated Oxygen Sensor (rear).
CAUTION:
To prevent damage to scan tool (M.U.T.-III), always turn the ignition switch to the "LOCK" (OFF) position before connecting or disconnecting scan tool (M.U.T.-III).
(1)Connect scan tool (M.U.T-III). Refer to HOW TO CONNECT THE SCAN TOOL (M.U.T.-III) See: Computers and Control Systems > Monitors, Trips, Drive Cycles and Readiness Codes OBD- II Drive Cycle.
(2)Start the engine and run at idle.
(3)Set scan tool (M.U.T-III) to the data reading mode for item AD, Heated Oxygen Sensor (rear).
a. Transaxle: 2nd (CVT: B range) speed
b. Drive with wide open throttle
c. Engine: 3,500 r/min or more
The output voltages should be between 0.6 and 1.0 volt.
(4)Turn the ignition switch to the "LOCK" (OFF) position.
Q. Is the sensor operating properly?
YES It can be assumed that this malfunction is intermittent. See: Vehicle > Initial Inspection and Diagnostic Overview > How to Cope With Intermittent Malfunctions.
NO Go to Step 2.
STEP 2. Check of short circuit to power supply in O2RL line between heated oxygen sensor (rear) connector and ECM connector.
Q. Is the harness wire in good condition?
YES Go to Step 3.
NO Repair the connector(s) or wiring harness. Then go to Step 4.
STEP 3. Using scan tool (M.U.T.-III), check data list item AD: Heated Oxygen Sensor (rear).
(1)Start the engine and run at idle.
(2)Set scan tool (M.U.T.-III) to the data reading mode for item AD, Heated Oxygen Sensor (rear).
a. Transaxle: 2nd speed (CVT: B range)
(3)Turn the ignition switch to the "LOCK" (OFF) position.
NO Replace the ECM (Refer to Removal and Installation See: Engine Control Module > Removal and Replacement > Engine Control Module (ECM) Removal and Installation). Then go to Step 4.
STEP 4. Test the OBD-II drive cycle.
(1)Carry out a test drive with the drive cycle pattern. Refer to Diagnostic Function - OBD-II Drive Cycle - Pattern 22 See: Computers and Control Systems > Monitors, Trips, Drive Cycles and Readiness Codes > OBD- II Drive Cycle.
(2)Check the diagnostic trouble code (DTC).
Q. Is DTC P0138 stored?
YES Retry the troubleshooting.
NO The inspection is complete.
172
DTC P0172: System too Rich
Fuel Trim Circuit
Refer to, DTC P0261 - Injector Circuit Low input - Cylinder 1 See: A L L Diagnostic Trouble Codes ( DTC ) > P Code Charts > Multiport Fuel Injection (MFI) , DTC P0264 - Injector Circuit Low Input - Cylinder 2 See: A L L Diagnostic Trouble Codes ( DTC ) > P Code Charts > Multiport Fuel Injection (MFI) , DTC P0267 - Injector Circuit Low Input - Cylinder 3 See: A L L Diagnostic Trouble Codes ( DTC ) > P Code Charts > Multiport Fuel Injection (MFI) .
CIRCUIT OPERATION
If a malfunction occurs in the fuel system, the fuel trim value becomes too large.
The ECM checks whether the fuel trim value is within a specified range.
Air/fuel learning value (long time fuel trim) and air/fuel feedback integral value (short time fuel trim) are too rich.
MONITOR EXECUTION
Continuous
Misfire monitor
Mass airflow sensor
Throttle position sensor
Jan 21, 2021 at 9:28 AM
  • 6 POSTS
Thanks for this info sir. We don't know if the oxygen sensor was likely the original since we are not able to monitor it while they are replacing the sensor (installed date: October 15, 2020), but the issue returns after several weeks (3rd week of November). As per mechanic (Mitsubishi dealer), they advise us to drain the remaining gas (unleaded) since they spectating that maybe in the fuel line is the problem. also they recommended to replace the existing fuel filter. i was worried since the status of the 3 codes was "stored" and they say that it is okay.
Jan 21, 2021 at 3:44 PM
Stored means inactive. The codes were present and active at one time but now are inactive.
Is the check engine light currently on?
Jan 21, 2021 at 6:54 PM
  • 6 POSTS
Yes, currently the check engine light is on, but sometimes, it's off randomly, as per experience of using this car, it jerks when the engine is hot.
Jan 22, 2021 at 8:48 AM
What are the current codes and did you replace the O2 sensor?
Jan 22, 2021 at 9:01 AM
  • 6 POSTS
Yes, they replace the oxygen sensor, see the image attached sir for reference.
Jan 22, 2021 at 9:12 AM
Okay, I see the connector is not on the sensor which leads me to believe you had a universal sensor installed. The new sensor should have a connector already attached and ready to the plugin.
The codes are inactive at the moment. You have airbag codes that are active and that is why the light is on. We need to start a new question to address those codes as I can only address one system at a time per question.
Jan 22, 2021 at 9:39 AM
  • 6 POSTS
Sir i just forgot to take the picture, the connector of the oxygen sensor was included on the box. they just removed it from the wires. i will upload another picture with the oxygen sensor and its connector. I was just wondering sir if the newly installed oxygen sensor is defective since the problem is the same before we replace the old one. Thanks Sir!
Jan 22, 2021 at 10:44 AM
With the codes inactive, my opinion is no, the codes are gone at the moment.
Your issue is with the airbag codes for the light.
roy
Jan 22, 2021 at 11:09 AM
  • 6 POSTS
Thank you so much sir!
Jan 22, 2021 at 2:00 PM
You are welcome.
Always glad to help.
Jan 22, 2021 at 8:29 PM
