Decode my radio
196,435 MILES • 4.0L • 4 CYL • 4WD • MANUAL
DOMINIC TARPEH
  • 6 POSTS
I have been using my car listed above for more than year without using radio due to the lack of means to access the code required.
VIN # SHHEU77201U018182
RADIO CODE: L 1303
U 0693
May 19, 2020 at 5:03 AM
In order to access your radio code you will need to submit your VIN and serial number from the radio and the verify you are the owner.
https://radio-navicode.honda.com/
Since your vehicle is a 2001 you will need to access the serial number on the sticker on the radio. You will need to pull the radio out to find this sticker.
Let me know if you have questions. Thanks
May 19, 2020 at 7:47 AM
