gear selector is hard to get out of park when on a steep hill
2004 FORD EXPEDITION
300,000 MILES
ZEESHAN KHAN
  • 13 POSTS
Dear Sir
I would like to ask a question that if we park (P) litter hilly place any ford, why gear is jam and sound to move (P), who we can avoid this and its dander for gear?
thanks
Regards,
Rao
Aug 7, 2013 at 1:09 AM
  • 110,244 POSTS
You are placing a lot of pressure on the parking sprag when it is on a hill. As a result, it is hard to move from park. You can avoid this very easily. Place the parking brake on so that it holds the vehicle in place. Then, place the vehicle in park. That way, the pressure is on the brake and not the transmission.
Aug 10, 2013 at 1:59 PM
ZEESHAN KHAN
  • 13 POSTS
thank you so much for your advise, do this gender ?
Aug 10, 2013 at 9:21 PM
  • 110,244 POSTS
I'm not sure what you mean by "do this gender." Can you explain?
Aug 11, 2013 at 1:53 PM
ZEESHAN KHAN
  • 13 POSTS
dear Sir,
i mean to say, if i forget to follow your instruction , it is danger to park without handbrake, if not so, even this is difficult to change the gear it is not effect the system,
Regards,
Rao
Aug 11, 2013 at 2:28 PM
  • 110,244 POSTS
Okay, now I understand. You should always use a parking brake when leaving the vehicle. However, placing it in park should hold the vehicle for you.
Aug 12, 2013 at 2:02 PM
