Dealer says recall was fixed and this is likely a fuel injector issue?
2021 KIA SELTOS
2.0L • AUTOMATIC
ALEEBULLET
Here is my list of symptoms:
Code P0304:
•A recurring Check Engine Light code indicating a specific cylinder misfire in Cylinder 4.
•The issue has persisted for over 1 year, always returning to the exact same cylinder despite parts being replaced.
•The Check Engine Light intermittently turns off on its own after a few smooth drives.
•Most recent scan at Valvoline detected a PERMANENT P0304 code.
Rapid Oil Loss:
•The engine oil has recently started draining and consuming much faster between services without leaving a visible puddle on the ground.
•My engine oil is halfway between Full and Low, yet it has been less than 2,000 miles since my last oil change.
Engine Ticking:
•A distinct metallic ticking noise coming from the engine that started about a year ago and has progressively worsened. It subsides after the engine warms up.
Metal on Sensor:
•An independent inspection by Christian Brothers Automotive physically discovered a metallic debris coating the magnetic crankshaft sensor which caused it to be damaged.
•Mechanic noted that there was no damage to the flex plate teeth.
Rough Starts:
•Intermittent, violent shaking and rough idling immediately upon starting the vehicle when the engine is COLD.
Acceleration:
•Car will not go past 2,500 RPM.
•Car will intermittently ‘fall back’ in power during acceleration. I can feel it physically when driving.
Constant Idle Vibration:
•A slight, continuous vibration felt through the car whenever the vehicle is turned on and idling.
A/C Shudder:
•When the A/C is turned on and the car is idling at a stoplight or in park, the engine experiences a sudden hiccup that feels like a shudder coming from the front hood.
•The A/C shudder has triggered a severe, uncontrollable shaking and jerking of the entire vehicle on a few occasions.
I took my car to the Kia dealership yesterday and they seem intent that this is all based on a bad fuel injector. They said they won't take into account the metallic debris on the crankshaft sensor because they didn't do the repair. I brought the car in to them back in March for the same recurring issues. They said it was bad spark plugs and 2 bad coils, which I had replaced. The first shop I visited was on 6/16/25 and that shop stated the spark plugs and coils were fine.
Does this seem like a bad fuel injector only? Or is something likely wrong with the engine? I am worried they are going to jerk me around and say it is only a fuel injector when the issue is much larger, just because they don't want to pay for an engine replacement.
What should I do? I don't know what is right and wrong. There was a recall, but they said it's been fixed and that's that. Please help!
Sep 4, 2026 at 11:28 AM
MECHTRIX
  • 529 POSTS
Honestly if this is a dealership and theyre the one that said it was ok keep all the records of the work being performed then I'd probably let them replace the injector ask abunch of questions get a printout repots of the diagnostic test that were preformed and if that completely solves the problem then great".. but if the problem continues after replacing it then youd most likely have a reason to request further action..especially after this has been an ongoing problem for such a long time and you were told it was ok so many times . That said .. this vary well could be the last problem solved id probably get the injector changed and go from there good luck o hope this helps you decide let us know were here to help
Sep 4, 2026 at 2:14 PM
ALEEBULLET
They haven’t given me any information yet. My car has been there all day at this point. It was the service advisor that was saying it’s probably a bad fuel injector when I dropped it off.
Is the metallic debris on the crankshaft sensor not a concern? They didn’t want to even check further. I had to agree to pay for additional diagnostic testing to get them to look past the fuel injector possibility.
Sep 4, 2026 at 2:20 PM
  • 55,423 POSTS
Can you please upload a short video of the engine noise? This vehicle may fall under Kia recall SC209/NHTSA 21V-259, involving certain 2021 Seltos models with the 2.0L Nu MPI engine. Improperly hardened piston oil rings can chip and score the cylinder walls, causing increased oil consumption, abnormal engine noise, engine damage, loss of power, and potentially connecting-rod bearing seizure. Kia’s recall remedy includes inspection, piston-ring noise-detection software, and engine replacement when the applicable failure is detected. Here is the recall
https://static.nhtsa.gov/odi/rcl/2021/RCLRPT-21V259-6845.PDF?utm_source=chatgpt.com
Sep 7, 2026 at 9:23 AM
