Engine will not stay running
168,000 MILES • 2.4L • 6 CYL • 2WD • AUTOMATIC
TRINA41
Replaced the alternator six months ago. I just replaced the starter and battery. it will start with a jump box on idle but when in drive it shuts off completely. no power at all. could you please suggest a next step. Thank you.
Feb 10, 2018 at 4:21 AM
CARADIODOC
  • 34,415 POSTS
Do you mean the entire electrical system is not working? If so, start by measuring the battery's voltage. It will be 12.6 volts if it is good and fully-charged. If it is good but fully-discharged, it will measure closer to 12.2 volts. If you find it at around 11 volts or less, it has a shorted cell and must be replaced.
Next, once you have the engine running with a jump-start, remove the jumper cables, then measure the battery voltage again. Tell me what you find with both tests.
Feb 10, 2018 at 6:07 AM
TRINA41
We replaced the battery due to a bad cell and it is still getting no power. it reads 12.5 fully charged but no power is getting to the car.
Feb 11, 2018 at 11:28 PM
CARADIODOC
  • 34,415 POSTS
Follow the smaller battery positive wire to the under-hood fuse box and be sure that connection is clean and tight. Follow the smaller negative battery wire to the body and be sure that one is tight and not rusty.
Feb 13, 2018 at 10:54 AM
