Will not turn over
169,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
MICHELLE WILLIAMS4
Changed alternator, battery is new, but car wont turn over. it clicks but wont crank. checked relay and ground.
Apr 21, 2019 at 10:00 AM
CJ MEDEVAC
  • 11,000 POSTS
Sometimes your battery connections are corroded or just not tight enough due to not being fully seated or the nut/ bolt is bottomed out or broken off. If you can move them bare-handed they are too loose.
Sometimes new things can be bad or go bad shortly later (most places give you a warranty on a battery).
It may be that with everything in good working order, but the "wire path" from the good alternator ain't making it over to charge the good battery (this may be a fusible link issue). Basically, you are running your battery down and the alternator is unable to help!
Will it jump start?
Is it possible your jumper cables were put on wrong (even for seconds)?
Let's look at these in this link under "Electrical"
https://www.2carpros.com/articles
Alternator Replacement
Alternator Test
Battery
Battery Cable Clean - Everything Goes Out
Battery Charge
Battery Flat Overnight
Battery Jump Start
Battery Load Test
Battery Replacement
Battery Symptoms
Return with good news!
The Medic
Apr 21, 2019 at 10:27 AM
MICHELLE WILLIAMS4
Could it be the computer needs to be reset? Where is it?
Apr 22, 2019 at 6:40 AM
CJ MEDEVAC
  • 11,000 POSTS
Answers to my above questions?
The Medic
Apr 22, 2019 at 8:18 AM
