Should a new battery only last a day?
100,100 MILES • 3.5L • V6 • AUTOMATIC
SLINTER86
I installed a brand-new battery. Even with a bad alternator, should my battery only last a day?
Jan 30, 2024 at 8:44 AM
  • 110,248 POSTS
It is very possible. It matters how much driving was done and what accessories were used. Check the alternator to confirm it isn't charging first. If it isn't, that is what should be replaced. If it is charging but the battery is failing, chances are we have a short in the system at some point.
Here is a link that explains how to test an alternator. All you need is either a voltmeter or a multi-meter.
Newer vehicles, such as yours, have so many different modules and electronics, they will drain a good battery rather fast. So, the idea that it only lasted a day doesn't surprise me.
Let me know. Also, I can help with the alternator if you find it is faulty.
Jan 30, 2024 at 12:38 PM
