dead battery
100,000 MILES
ANNNNN
I think I see where to attach the positive, but the fuse box sits right on top of the negative. The whole battery is cover with a yellow plastic casing which appears non-removable. The positive seems to be sticking out on the side. But I'm not even sure that's the place to hook on the cable either.
May 5, 2013 at 3:32 AM
JDL
  • 16,098 POSTS
Move the fuse box out of the way.
Remove the cover from the underhood electrical center.
Remove the bolt retaining the underhood electrical center to the upper tie bar.
Rotate and remove the electrical center from the right sheet metal diagonal brace.
You may have to remove diagonal brace as well.
May 5, 2013 at 4:29 AM
