This sounds like you have a headlight switch that has gone out or the BCM needs to be replaced, we should run a CAN scan which is easy, you can get a CAN scanner (Controller Area Network) from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
This will confirm the BCM failure. Also, I have included the headlight wiring diagrams so you can see how the system works and which wires to test to make sure the switch is still working.
This guide can help:
I have also included how to change the headlight switch out and the BCM in case you need them. You can get a preprogrammed BCM by searching Google or Ebay. Check out the images (below). Please let us know what you find. We are interested to see what it is.
Images (Click to enlarge)
Mar 26, 2023 at 4:35 AM
