how to remove and reinstall the entire dashboard?
2005 PONTIAC GRAND PRIX
150,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
JAMESB2019
  • 42 POSTS
I need instructions on how to remove and reinstall the entire dashboard (so as to expose the HVAC unit).
Nov 5, 2022 at 6:14 AM
  • 110,241 POSTS
I attached directions below for the removal of the HVAC box. I'm not sure what exactly you are after, but if it is the heater core or evaporator, I don't think you need to remove everything.
Regardless, pic 20 starts the dash removal.
I hope this helps.
Nov 6, 2022 at 12:19 PM
JAMESB2019
  • 42 POSTS
Hello Joe,
Yeah, thanks for asking. At first, I was planning to replace the broken ventilation trim piece (they always break due to heat and cold variations). Then, I realized I didn't have to. There is also adhesive stickers all over the passenger air bag area, I was frustrated about how it all looked, but then I decided to use a heat gun and goo off material to take the adhesive backing off. So, no need to remove the dashboard or replace it. I am just going to replace the trim piece and do some cleaning up. Thanks again
Nov 7, 2022 at 10:50 AM
  • 110,241 POSTS
You are very welcome and thanks for the update. As far as repairs are concerned, if anything changes, let me know.
Nov 7, 2022 at 11:24 AM
