Dashboard meters quit together
2000 GMC JIMMY
275,000 MILES • 6 CYL • 4WD • AUTOMATIC
MORNINGSTAR
  • 15 POSTS
The speedometer, tachometer and odometer have all quit working at the same time. I changed the Gauges and Cluster fuses (both 10A) did not work. Runs fine, but I need them.
May 27, 2016 at 2:04 PM
HMAC300
  • 48,601 POSTS
have it checked for a bad cluster they are digital and do that. they can be rebuilt. but some must be reprogrammed to your vehicle.
May 27, 2016 at 11:17 PM
MORNINGSTAR
  • 15 POSTS
Thanks, I will do that.
May 28, 2016 at 3:34 AM
  • 55,104 POSTS
You can replace it with a used unit as well but the mileage will be off, or send it in to be rebuild there are many that can do it.
http://www.gmpartspros.com/oe-gm/10373952?origin=pla&gclid=CLWk2MLM_8wCFU1rfgodTeQEoA
here is a link
May 29, 2016 at 1:30 AM
MORNINGSTAR
  • 15 POSTS
Thanks for the link. I have not decided whether I will replace it It is a 2000, and there is some other work that needs doing too. It may not be worth the cost, if it does not stop me from driving it. I will probably have to replace the vehicle within the year anyway.
Thanks for your help. I was really hoping it was the fuse, and would be a cheap, easy fix.
May 29, 2016 at 3:03 AM
  • 55,104 POSTS
Sorry about that, gad we could help though.
May 29, 2016 at 3:50 AM
