Dashboard lights not working properly
175,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
RAGINGSOUL
  • 54 POSTS
My dashboard lights fade out. If I push on the light switch or push on the dimmer switch and the lights may come on and stay or or they will fade out again. A bump in the road will also make them go on and off.
Is this the that you adjust you headlights with faulty? I greatly appreciate any help you have to offer.
Aug 21, 2020 at 12:09 AM
  • 110,246 POSTS
Based on your description, it does sound like the switch is bad. What to do is before replacing it, check to make sure there isn't a loose connection at the switch or corrosion causing problems where the switch and wiring connect.
If you find the switch is bad, here are the directions or replacement. The attached pics correlate with the directions.
____________________________________________________
2004 Chevy Truck Tahoe 2WD V8-5.3L VIN Z Flex Fuel
Procedures
Vehicle Sensors and Switches Sensors and Switches - Lighting and Horns Headlamp Switch Service and Repair Procedures
PROCEDURES
HEADLAMP SWITCH REPLACEMENT
REMOVAL PROCEDURE
1. Remove the instrument cluster bezel.
pic 1
2. Unsnap the switch from the housing.
3. Disconnect the electrical connectors.
pic 2
4. Remove the switch.
INSTALLATION PROCEDURE
pic 3
1. Connect the electrical connectors.
pic 4
2. Install the headlamp switch by snapping the headlamps switch into place.
3. Install the bezel to the instrument panel.
Let me know if this helps.
Aug 21, 2020 at 2:45 AM
FREEMBA
  • 1,152 POSTS
It sounds like the instrument panel dimmer switch (it's part of the headlight switch) is defective. When they go bad the instrument panel will behave in the manner you described.
Test it by wiggling the dimmer rheostat ("wheel")and watching the instrument panel lights. If they flicker, dim or go out during this process the dimmer rheostat (dimmer switch) needs to be replaced.
In order to replace the dimmer switch you'll have to remove the instrument panel trim piece.
Use the video link below in order to remove the instrument panel trim piece (you'll have to watch about 31 seconds of the video).
https://youtu.be/_HEC44xENxw
Once the rim piece is removed, use a "Flathead" screwdriver to carefully pry the headlight switch out of the dash. Unplug the wire connector. Reverse this process to install the switch.
Aug 21, 2020 at 2:55 AM
RAGINGSOUL
  • 54 POSTS
Thank you both for your help. I have the part ordered. If I need more help I'll let you know. Thanks again.
Aug 22, 2020 at 4:01 AM
  • 110,246 POSTS
You are very welcome. If you have a chance, please let us know if that takes care of the problem.
Aug 22, 2020 at 2:46 PM
RAGINGSOUL
  • 54 POSTS
Just wanted to let you know that changing the switch out worked. Thanks for your help.
Aug 30, 2020 at 9:36 PM
  • 110,246 POSTS
That's good news. I'm glad it took care of the problem for you. Please feel free to come back anytime you have questions in the future.
Take good care of yourself.
Sep 1, 2020 at 11:09 AM
