Dashboard heater/AC fan switch not working properly
120,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
MISSKATE
  • 5 POSTS
The dashboard switch that controls the speed of the heater/AC fan will not work. Actually, it works intermittently; I will press the switch until all speeds are highlighted but no air comes out. If I leave it on high, it will sometimes come on about fifteen minutes later. But sometimes it will not come on at all. How can this be repaired?
Jan 4, 2018 at 4:21 AM
  • 55,808 POSTS
This sounds like you have a problem with the blower motor or the controller. Here is a guide to help us test and replace the blower motor:
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Here are blower motor wiring diagrams so we can test for power loss:
Please run down these guides and diagrams and report back (below).
Cheers, Ken
Jan 5, 2018 at 7:16 AM
MISSKATE
  • 5 POSTS
Could it possibly be blower resistor?
Jan 8, 2018 at 3:51 AM
  • 55,808 POSTS
Yes it could when you remove it please look for anu burn marks on the resistor which will tell you the unit is bad. If you have a question about it please upload an image of the part in question.
Jan 8, 2018 at 4:08 AM
MISSKATE
  • 5 POSTS
Thank you for all your help. I think however, I am going to have to take it to someone. I am pretty handy but this really intimidates me.
Jan 8, 2018 at 5:30 AM
  • 55,808 POSTS
Before you take it in can you please remove the resistor and take a picture of it for me so I can tell you if that is your problem? If not I understand. Please let us know what the shop finds and if you can get a picture of the failed part so you can upload it the problem will be solved for others.
Cheers, Ken
Jan 9, 2018 at 3:00 AM
