Dashboard cd radio panel light problem
89,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
MARKONI
My Honda Jazz has a problem Light bulb are located cd radio control panel aux-am-fm selections button. How can I replace that lamp
Thanks
best rgds
Jan 20, 2014 at 3:12 PM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
pull the radio out and make sure you have the theft code if its the factory unit. if you can get the back off the radio then you may be able to replace the bulb. sometimes the lighting is integrated and cant be serviced. you could also call Honda or a radio service shop and ask about repair and/or replace the unit
Jan 27, 2014 at 8:29 AM
