Dash went crazy.
190,000 MILES
CTZIMMERMAN
I was coming home from work and the check oil light came on. Then the rest of the lights started flashing at the same time as the temp gauge and tachometer started oscilating between the correct measurement and zero. I checked the oil, it was low so I added it. Now when I start the car the dashlights all stay on, the rpms and temp gauge do not work. And the lights on the shift lever (its an automatic) are also dark.
Apr 16, 2013 at 10:37 AM
it sounds like you have a cluster that has failed.
roy
Apr 16, 2013 at 10:45 AM
CTZIMMERMAN
Safe to drive?
Easy/cheap to fix?
Apr 16, 2013 at 10:48 AM
i would not drive it as you cannot monitor the gauges
eays, but pricy
roy
Apr 16, 2013 at 10:50 AM
CTZIMMERMAN
How would I find out what part I would need? Is it the whole instrucment panel or just a part?
Apr 16, 2013 at 10:57 AM
CTZIMMERMAN
The speedometer and the fuel gauge both work.
Apr 16, 2013 at 11:00 AM
