Dash ABS warning light intermittent appearance
445,000 MILES • 3.5L • V8 • 2WD • AUTOMATIC
MIKE STRINGER
Every once in a while during driving, the ABS warning light appears at the same time the Emergency Brake warning light appears. They disappear on shut down, and most often don't reappear for days - sometimes weeks. I've recently had a complete brake overhaul making me sure my brake system is in good working order.
Sep 6, 2020 at 6:57 AM
Good afternoon,
You have a fault stored in the ABS system. It could be as simple as a wheel speed sensor but we need the code to be sure.
It sounds like you may have a wheel speed sensor that is out. These videos will help us find the problem.
https://youtu.be/rTtAnsOlZU4
and
https://youtu.be/Pb6nXV-iamI
and
https://youtu.be/ANWVTh2RQoQ
and
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
You can go to a parts store and they will read the code for free.
It has nothing to do with the mechanical side of the brakes.
Mar 13, 2021 at 3:40 AM
MIKE STRINGER
Last month I visited a Chevrolet dealer for an oil change; they checked for codes and got nothing. I'm mystified by this issue.
That was last month and this is now.
You need to have them checked at a parts store. If they cannot read the ABS codes, then you will need a shop that can access the ABS system and check history codes.
MIKE STRINGER
Okay. Thank you Roy. Mike
You are welcome.
Always glad to help.
