dash meter showing AT signal and car goes lamb
128,000 MILES • 4 CYL • 2WD • AUTOMATIC
OMAR FARUQ
for recently few days i am facing a big problem which is AT signal !
my car suddenly shows AT signal when slowing down or coming to a stop and car make a high jerking and speed done both ahead and reverse
here mechanics are not very expert about Mazda . they are telling me to change the Transmission Box directly
but i can feel that no need to change transmission box cause i can easily hit 160 ~180 kmph speed
and the At signal not showing in running high speed
Sep 9, 2016 at 6:27 AM
SATURNTECH9
  • 30,869 POSTS
Can you take a picture of the light that's coming on and post it?I just and a 2005 Mazda 3 that had the transmission light on and was slamming into drive and reverse and was in limp mode.At that point I couldn't talk to the transmission computer it ended up being a bad transmission computer.Have you had it scanned for codes yet?
Sep 10, 2016 at 2:33 PM
OMAR FARUQ
yes dear i for normal mode its showing that onxygen sensor failed Bank1-sensor1
and when At light showed after scan its showing VSS sensor problem but i changed VSS sensor and its same !
not sharing picture but have a video, can you please sir see it ?
https://www.youtube.com/watch?v=84LecGn20Wg
Sep 11, 2016 at 3:41 AM
SATURNTECH9
  • 30,869 POSTS
I saw it so do you have the exact code numbers not code descriptions?That would be a letter followed by a four digit number..
Sep 11, 2016 at 7:41 AM
