My headlights turn off when adjusting the steering column. Now nothing is working.
Oct 4, 2020 at 10:52 AM
✓Experienced Mechanic
If moving the column was causing them to turn off and now nothing works, chances are you have a short in the column and have blown the primary lighting fuse. The fuse is located under the hood in he fuse box. (Lighting fuse 8)
