Dash lights only come on when rear defrost is on
2005 KIA SPECTRA
230,000 MILES • 2.0L • 4 CYL • FWD • MANUAL
LOCKHARTBILL
I own the LX model. My check engine light came on after an exhaust leak. i used an OBD II code reader to check and clear the code. Three days after clearing the code the rear defrost light came on and stayed on for about a day then it went out. The next day the dash lights stopped working strangely they came on when the rear defrost was turned on and would turn off when the rear defrost was turned off. I checked all the fuses on inside panel and under the hood, i disconnected the battery and let it sit for a few minutes then reconnected. i also disconnected switch for defrost. I also checked light switch. None of it seemed to help not sure what else to check. Any ideas?
Mar 3, 2017 at 12:58 AM
KHLOW2008
  • 41,814 POSTS
Quite likely the Body control module or its wiring system is faulty. It could be due to a bad ground sonewhere and this is not going to be easy to diagnose and rectify.
Mar 4, 2017 at 6:35 PM
