nothing on dash works, instrument panel, lights, or radio. replaced battery and fuses
Jul 15, 2026 at 7:32 PM
WKELLEY2026
MEMBER
nothing on dash is working, instrument panel, radio, dash lights. replaced fuses and battery
Jul 15, 2026 at 9:14 PM
(Merged)
STEVE W.
✓Experienced Mechanic
To clarify, do you mean things are not lighting up or that things like the radio doesn't operate or the gauges are not working? Does it start and run without an issue? What on the dash does work? Can you turn on the interior lights? Need to narrow down what might be the failure point. Did they all fail at the same time or has it been a while?
