Dash lights flickering
206,000 MILES • 4.2L • 6 CYL • 2WD • MANUAL
HIAWATHA_MAN
My issue has two parts. Part one: The issue I am having is my dash lights will start flickering and my gauges will stop working while I am driving down the road. They will start working ten to fifteen seconds later. Part two: when I go the start my truck the dash lights will flicker, gauges do not move, the truck will turn over but shuts off two seconds later. I know your thinking alternator or battery but the kicker is I can give the dash a hammer fist and it all starts working. What do you think the problem is? I have a video but it is too large to upload.
Aug 29, 2017 at 7:11 AM
  • 55,721 POSTS
On the dash lights and gauges it sounds like you have a bad connection at the instrument cluster. I would remove the cluster and unplug it, then plug it back in again, this should clean the connections and make it work again.
Cheers, Ken
Aug 30, 2017 at 5:24 AM
STEVE W.
  • 15,413 POSTS
I would also check the fasteners used to secure the dash to the truck. Those are part of the ground circuit and if they are corroded/loose they will cause a lot of headaches. The easy way to test this is to find a piece of the metal in the dash and run a wire from it to a clean bare spot on the body or straight to battery negative. If the issue goes away it is a bad ground.
Aug 30, 2017 at 8:13 AM
