Dash, brake and battery lights on?
197,000 MILES • 4 CYL • 2WD • AUTOMATIC
GIANNO
Took meter on battery, okay, alternator okay, brake fluid okay.
Aug 14, 2023 at 3:35 AM
  • 55,709 POSTS
It sounds like the IPC might be bad, but I would check the fuses first and then run the codes to see if any are stored. Please go over these two guides:
and this is how to do a CAN scan. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Here is how to change the cluster out, you can get a preprogrammed unit by searching Google or Ebay.
Aug 15, 2023 at 2:01 AM
