Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
Sonoma
Interior
Dashboard
Light
Dash lights
2003 GMC SONOMA
180,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
RICHARD LONSKI
MEMBER
A few times a day all the dash lights will light up and go off. There is no loss of power and I do not get a code.
Nov 7, 2018 at 5:28 PM
Experienced Mechanic
Good morning.
The first thing I would do is clean the battery cables. Low voltage will cause this issue.
Beyond that, I would check the connector behind the dash for being tight and clean.
If that does not take care of it, then I would consider having the cluster removed and sent out to see if there is an internal issue in the cluster.
Nov 7, 2018 at 10:00 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
