Dash lights
104,000 MILES • AUTOMATIC
MATTPLAIN1992
I have been driving my car for about three months now. A few times that I have drove my car all of my dashboard lights have came on and then shut off they were only on for a few seconds. But the last time I drove my car all of the dashboard lights came on and when I went to go pull over to the side of the road my car stalled and quit. When I first got the car I think it had approximately a hundred thousand miles on it, I do not drive it very far.
Dec 27, 2017 at 6:26 AM
STEVE W.
  • 15,413 POSTS
The description sounds like a loose connection either at the battery or at the fuse panel under the hood. I would start by removing and cleaning the battery cable connections at both ends. Then verify that the ground connections to the engine and body are good. I would suspect loose battery connections especially if it sat on a car lot, they usually disconnect the battery so they do not drain setting there. More than once they just stick the terminal on enough to start the engine and move the car. Then if someone buys it, they forget to tighten it down.
Dec 29, 2017 at 12:03 PM
