dash lights
103,000 MILES
BUCKSHOTRICK
all my dash lights went out at once. I have changed all the fuses but still do not work. Any ideas
Apr 13, 2013 at 1:18 AM
there is one fuse in the fuse box that is only hot when the headlights are on. that is the fuse for the dash lights. check it only with a test light to verify voltage
otherwise you have a failed cluster
Apr 13, 2013 at 1:42 AM
