all my dash lights went out at once. I have changed all the fuses but still do not work. Any ideas
Apr 13, 2013 at 1:18 AM
✓Experienced Mechanic
there is one fuse in the fuse box that is only hot when the headlights are on. that is the fuse for the dash lights. check it only with a test light to verify voltage
otherwise you have a failed cluster
Apr 13, 2013 at 1:42 AM
