dash light issues PRNDL and mileage ?
152,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
WIMMS77
  • 12 POSTS
so on my dash everything works except for the lights that show the PRNDL and mileage I have googled it looked it the repair manual and tinkered with it until I'm fed up trying to figure it out on my own so can you please help me try to fix this issue
Jan 19, 2026 at 2:28 AM
KRAKENAUTO
  • 107 POSTS
The power to these is controlled by the headlight switch. If it's not dimmed, I would first try a new headlight switch.
Jan 20, 2026 at 1:47 PM
WIMMS77
  • 12 POSTS
already did that and still no headlights I have dash lights just not the prndl or mileage shows anymore
Jan 22, 2026 at 6:03 AM
WIMMS77
  • 12 POSTS
I've been working with another guy from your site on my headlights but he said I had to do another ? about this issue seperatly
Jan 22, 2026 at 6:05 AM
  • 55,540 POSTS
I would check the four fuses that run the cluster first and if they are okay chances are the cluster itself is bad. What happens is the LED board or the driver goes out so the cluster will need to be rebuilt, you can search google or ebay for a rebuilder but lets check the fuses first this guide can help with the fuse location in the images below.
you can try a reboot as well, this might work
https://www.youtube.com/watch?v=INiDRO5A5MY
Jan 24, 2026 at 2:16 AM
WIMMS77
  • 12 POSTS
idk if I been talking to another man on here about the headlights not working even tho I switched the pull knob switch out and I only have brights when I pull and hold my turn signal forward while driving otherwise no head lights I had told him that the fuse box under my hood there's a spot that should have a 15 fuse in it but it won't let me place 1 in it and that in this same area of this fuse box when I used my test light some of them didn't light up with my test light on either side of the fuse is this normal and can a fuse be bad even if it's not blown or burnt out by chance
Jan 24, 2026 at 10:12 PM
  • 55,540 POSTS
I would remove the fuses above and look at them to see if any are blown. What ever happens to the headlight problem did you get it fixed? I don't see that thread in the que?
Jan 25, 2026 at 12:35 AM
WIMMS77
  • 12 POSTS
no we r still trying to figure it out so far I put in a new pull knob switch nothing checked every fuse related to them all good he suggested me trying to use a needle and a wire at the wire harness connector behind the glove compartment which I haven't been able to do because it's freezing here with close to a foot of snow plus I'm not electronically inclined so I'm scared il mess it up or do it wrong but I'm going to bundle up turn on the heater and see what I can learn here shortly plus attempt your suggestions from earlier as well then I will lyk from there
Jan 25, 2026 at 1:07 AM
  • 55,540 POSTS
Yep, the snow is brutal right now, hang in there and let me know what you find.
Jan 25, 2026 at 11:53 PM
WIMMS77
  • 12 POSTS
ok so this car has been a headache since I got it and I've worked with y'all on many issues 1 being the headlights not working and it's still a work in progress to fix them but I'm wondering if it could maybe be a electrical issue instead because my dash lights all work except the prndl and mileage haven't been coming on at all until yesterday when they came on when I started it but when I turned it off and back on nada and my climate control knobs won't turn off at all when it turn it and the light for the AC on the dash always stays on and the windows mainly the driverside won't stay or go up even though the buttons work and try to lift it also even after turning off the key sometimes even after pulling it out the low coolant light stays on the dash and low tire even tho it's got coolant and air in the tires at 30-32 psi does this sound like electric issues to you
Mar 12, 2026 at 1:38 AM (Merged)
