Code p0507, dash light ESP and ETC lights
338,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
MATTSTORMS42
  • 26 POSTS
Will driving the "ETC" lightning bolt symbol will come on followed by "ESP" car wavy lines symbol. Car engine will "rev" a little high and surge in power on/off.
It will reset if the ignition is turned off, wait a minute or two and restart engine, lights clear off dash and van drives fine.
Also have a reoccurring "check engine" light. Ran a scanner on it, p0507 is the trouble code it reads.
What do i need to do to fix these?
Thanks
May 14, 2022 at 7:06 AM
SQM
  • 6,383 POSTS
The traction and stability control lights can get triggered when the system detects any faults within any of the components. It could be a wheel speed sensor, wiring issue or even a module. These are primarily related to the ABS system of the vehicle.
A good first step would be to scan the vehicle and retrieve the codes for the system.
https://youtu.be/rTtAnsOlZU4
As for the P0507 code, it is typically due to issues with the throttle body, leak in the air intake system, vacuum leak, or even the PCM.
I have attached the trouble shooting steps for the code P0507 below. Follow those steps as it can help you determine the issue.
Let me know of any questions.
May 14, 2022 at 12:38 PM
