The dash lights and gauges go out but sometimes come back on. I replaced instrument cluster and TIPM, do you have any idea what could be going on?
May 4, 2023 at 9:45 AM
✓Experienced Mechanic
This sounds like the dimmer switch is going out here is the instrument cluster lighting wiring diagrams so you can see how the system works and I have included how to change the dimmer switch out as well. Check out the images (below). Please let us know what happens.
Images (Click to enlarge)
May 5, 2023 at 2:30 AM
DODGE PERSON
MEMBER
Is this diagram for a 2013 Dodge caravan? Also, I forgot to mention wipers come on gauges don't work, turn signals won't work, and dash doesn't light up. what could be happening?
May 5, 2023 at 11:39 AM
Yes, the diagrams are for a 2013 Dodge caravan. It sounds like you have a defective TIPM, but to be sure let's do a CAN scan. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
